Aller au contenu principal
Garmin StreetPilot c330 Speakers Replacement
Ce dont vous avez besoin
  1. Garmin StreetPilot c330 Speakers Replacement, Outer Casing: étape 1, image 1 de 3 Garmin StreetPilot c330 Speakers Replacement, Outer Casing: étape 1, image 2 de 3 Garmin StreetPilot c330 Speakers Replacement, Outer Casing: étape 1, image 3 de 3
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot c330 Speakers Replacement: étape 2, image 1 de 3 Garmin StreetPilot c330 Speakers Replacement: étape 2, image 2 de 3 Garmin StreetPilot c330 Speakers Replacement: étape 2, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot c330 Speakers Replacement: étape 3, image 1 de 2 Garmin StreetPilot c330 Speakers Replacement: étape 3, image 2 de 2
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot c330 Speakers Replacement: étape 4, image 1 de 3 Garmin StreetPilot c330 Speakers Replacement: étape 4, image 2 de 3 Garmin StreetPilot c330 Speakers Replacement: étape 4, image 3 de 3
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot c330 Speakers Replacement: étape 5, image 1 de 1
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
  6. Garmin StreetPilot c330 Speakers Replacement, Battery: étape 6, image 1 de 3 Garmin StreetPilot c330 Speakers Replacement, Battery: étape 6, image 2 de 3 Garmin StreetPilot c330 Speakers Replacement, Battery: étape 6, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the two screws from the battery bracket.
  7. Garmin StreetPilot c330 Speakers Replacement: étape 7, image 1 de 3 Garmin StreetPilot c330 Speakers Replacement: étape 7, image 2 de 3 Garmin StreetPilot c330 Speakers Replacement: étape 7, image 3 de 3
    • Carefully peel the metal bracket away from the battery.
    • Pull the battery away from the back cover.
    • Desolder the wires from the speakers using a soldering iron.
  8. Garmin StreetPilot c330 Speakers Replacement, Speakers: étape 8, image 1 de 2 Garmin StreetPilot c330 Speakers Replacement, Speakers: étape 8, image 2 de 2
    • Carefully use the spudger to pry the speakers from the outer casing.
    • Once removed, you may use a soldering iron to remove the wires from the speakers.
Michael
Membre depuis le 10/07/10
107 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 22-1, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-1, Maness Fall 2010
CPSU-MANESS-F10S22G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,711
