Introduction
This is a guide on how to remove the hard drive on this lap top. Reasons for removal of the hard drive are the current one has stopped working, or to get upgrade to a more improved hard drive.
Pièces
Aucune pièce nécessaire.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Ajouter un commentaire
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
The hard drive is located on the bottom of the laptop on the left hand side.
  • The hard drive is located on the bottom of the laptop on the left hand side.
Remove the two scores on the cover with the screwdriver specified.
  • Remove the two scores on the cover with the screwdriver specified.
Lift off the cover with the plastic opener.
  • Lift off the cover with the plastic opener.
Unscrew the one screw holding the hard drive in place with the same screw driver.
  • Unscrew the one screw holding the hard drive in place with the same screw driver.
Slide the hard drive up and remove it from the laptop.
  • Slide the hard drive up and remove it from the laptop.
2 autre(s) ont terminé cette réparation.
Kyle
Membre depuis le 11/03/2014
622 Réputation
10 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-2, Calaway Spring 2014 Membre de l'équipe UMass Dartmouth, Team 3-2, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G2
4 membres
18 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 239
