Introduction
LCD (liquid crystal display) is another term to use for display in computer or technology device. LCD is need to replace if the screen was not on or if it is damage by any other factor like water, crack by contacting to the hard surface.
LCD damage can make a laptop unusable, so it is necessary to replace it as soon you could.
Pièces
Aucune pièce nécessaire.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Ajouter un commentaire
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
Using the Phillips #0 screwdriver, remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back cover, as marked here. Using the Phillips #0 screwdriver, remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back cover, as marked here.
  • Using the Phillips #0 screwdriver, remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back cover, as marked here.
Pry off the keyboard by placing your plastic opening tool on the center of the top row of keys, as shown in the photograph. If the plastic opening tool bends or slips, use something sturdier, such as the Phillips #0 screwdriver. Remove the keyboard.
  • Pry off the keyboard by placing your plastic opening tool on the center of the top row of keys, as shown in the photograph.
  • If the plastic opening tool bends or slips, use something sturdier, such as the Phillips #0 screwdriver.
  • Remove the keyboard.
Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
  • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage. Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
  • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
  • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
Pry the border around the monitor off of the top cover using a plastic opening tool, as shown. Be careful not to damage the computer screen in the process. Be careful not to damage the computer screen in the process.
  • Pry the border around the monitor off of the top cover using a plastic opening tool, as shown.
  • Be careful not to damage the computer screen in the process.
Separate the monitor from the border cover once all snap connections have been pried apart. Separate the monitor from the border cover once all snap connections have been pried apart.
  • Separate the monitor from the border cover once all snap connections have been pried apart.
Remove the six (6) 5mm screws shown here using the Phillips #0 screwdriver.
  • Remove the six (6) 5mm screws shown here using the Phillips #0 screwdriver.
Take the screen out of the top cover. Take the screen out of the top cover.
  • Take the screen out of the top cover.
My Linh Pham
Membre depuis le 11/03/2014
301 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-2, Calaway Spring 2014 Membre de l'équipe UMass Dartmouth, Team 3-2, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G2
4 membres
18 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 179
