Introduction
This is the guide for complete removal of the Gateway LT41P10u monitor. When removing monitor handle with care to avoid possibly cracking the screen.
Pièces
Aucune pièce nécessaire.
Place the laptop upside down on a flat surface so you can see the battery (marked in red).
  • Place the laptop upside down on a flat surface so you can see the battery (marked in red).
Ajouter un commentaire
Pull the two marked tabs towards the outside of the computer to unlock them.
  • Pull the two marked tabs towards the outside of the computer to unlock them.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
  • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
Carefully use a spudger to separate the monitor from top panel. Gently remove lower hooks from the hinges. (see second image)
  • Carefully use a spudger to separate the monitor from top panel.
  • Gently remove lower hooks from the hinges. (see second image)
Once you completed separating the monitor from the top panel disconnect the cable shown here in red by raising the cable lock and pulling the wires away. The second image is how it should look once completely disconnected.
  • Once you completed separating the monitor from the top panel disconnect the cable shown here in red by raising the cable lock and pulling the wires away.
  • The second image is how it should look once completely disconnected.
To reinstall your device, follow these instructions in reverse order.
Michael Smith
Membre depuis le 19/10/2017
401 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S66-G8, Rockett Fall 2017 Membre de l'équipe UMass Dartmouth, Team S66-G8, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G8
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 18
