Introduction
Removal of the CD/DVD drive. Use this guide to replace a defective CD/DVD drive, in the case that your disk drive is not working. If it's a problem with the drive itself, you will need a new one, otherwise there may be an issue with the device itself.
Outils
Aucun outil requis.
To prevent injury, make sure the laptop is unplugged before removing the battery.
  • To prevent injury, make sure the laptop is unplugged before removing the battery.
  • Push the locking tab over to the right away from the battery to unlock it from the laptop.
  • Hold the additional locking tab to the left while puling out the battery.
Ajouter un commentaire
Remove the following screws securing the plastic panel from the bottom of the laptop: Remove the seven 6 mm screws with a Phillips #0 screwdriver
  • Remove the following screws securing the plastic panel from the bottom of the laptop:
    • Remove the seven 6 mm screws with a Phillips #0 screwdriver
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Pull upwards on the top of the plastic panel to remove it. With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece. With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
  • Pull upwards on the top of the plastic panel to remove it.
  • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
Remove the following screws holding the DVD/CD drive in place: One 6 mm Phillips #0
  • Remove the following screws holding the DVD/CD drive in place:
    • One 6 mm Phillips #0
Use the edge of a plastic opening tool to push down on the metal latch preventing the drive from being pushed out.
  • Use the edge of a plastic opening tool to push down on the metal latch preventing the drive from being pushed out.
  • While pressing down, push the metal latch out away from the laptop.
Once the drive has been pried out, you can pull the CD drive out. Once the drive has been pried out, you can pull the CD drive out. Once the drive has been pried out, you can pull the CD drive out.
  • Once the drive has been pried out, you can pull the CD drive out.
Tim Rose
Membre depuis le 05/03/2018
365 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G2, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S6-G2, Bernier Spring 2018
UMASSD-BERNIER-S18S6G2
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 52
