Introduction
This guide shows the user how to properly remove the screen from the Gateway MS2370 Laptop.
Pièces
Aucune pièce nécessaire.
Make sure the laptop is turned off and  flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
Ajouter un commentaire
Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
Pull the battery from the laptop to remove it.
  • Pull the battery from the laptop to remove it.
Using the pointed tweezers, remove plastic circles that are stuck onto the back of the laptop’s hinges.
  • Using the pointed tweezers, remove plastic circles that are stuck onto the back of the laptop’s hinges.
  • These plastic circles are stuck inside the hole with adhesive and might require a significant amount of force.
Unscrew both of the 3mm Phillips 01 screws on both hinges using the matching screwdriver. Unscrew both of the 3mm Phillips 01 screws on both hinges using the matching screwdriver.
  • Unscrew both of the 3mm Phillips 01 screws on both hinges using the matching screwdriver.
Take the plastic spudger and pull up the tabs on all four sides of the screen molding.
  • Take the plastic spudger and pull up the tabs on all four sides of the screen molding.
Carefully remove the screen molding. Be aware that the screen molding will not come out all the way.
  • Carefully remove the screen molding. Be aware that the screen molding will not come out all the way.
Unscrew the four 3mm inch Phillips 01 screws on the screen bracket.
  • Unscrew the four 3mm inch Phillips 01 screws on the screen bracket.
Peel up the tape over the connector and unplug the screen from the laptop. Peel up the tape over the connector and unplug the screen from the laptop. Peel up the tape over the connector and unplug the screen from the laptop.
  • Peel up the tape over the connector and unplug the screen from the laptop.
Slowly remove the screen from the laptop. Slowly remove the screen from the laptop.
  • Slowly remove the screen from the laptop.
Mathieu Bolduc-Clayton
Membre depuis le 17/10/2017
401 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G5, Simcock Fall 2017 Membre de l'équipe UMass Dartmouth, Team S1-G5, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 61
