Introduction
This Guide will help you replace a Gateway Disk Drive.
Move the latch to the right of the battery to unlock.
  • Move the latch to the right of the battery to unlock.
Ajouter un commentaire
Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
  • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
  • The latch must be held in position to remove the battery.
Unscrew the marked 5.9 mm Philips screw.
  • Unscrew the marked 5.9 mm Philips screw.
Use the spudger to pry out the Disk dive.
  • Use the spudger to pry out the Disk dive.
The disk drive should easily detach and can now be replaced.
  • The disk drive should easily detach and can now be replaced.
Diego Carteno
Membre depuis le 15/04/2010
247 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 24-20, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 3,177
