Introduction
The guide will detail the replacement of the back panel of the HP 15-BA078DX.
Unclip the two latches on the bottom of the laptop. Slide the battery straight out while holding the clip open. Slide the battery straight out while holding the clip open.
  • Unclip the two latches on the bottom of the laptop.
  • Slide the battery straight out while holding the clip open.
Ajouter un commentaire
Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
  • Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool. Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool. Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
  • Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
  • Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
  • Remember to remove the two screws under the rubber feet.
Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart. You may need to flip the laptop over to unlatch all of the internal clips. You may need to flip the laptop over to unlatch all of the internal clips.
  • Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
  • You may need to flip the laptop over to unlatch all of the internal clips.
Carefully pull the shell of the computer apart. Carefully pull the shell of the computer apart. Carefully pull the shell of the computer apart.
  • Carefully pull the shell of the computer apart.
Benjamin DosSantos Jr
Membre depuis le 20/03/2018
361 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G4, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G4, Peak Spring 2018
UMASSD-PEAK-S18S3G4
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 22
Total : 38
