Aller au contenu principal
HP 15-ac121dx Fan Replacement
Ce dont vous avez besoin
  1. HP 15-ac121dx Fan Replacement, Battery: étape 1, image 1 de 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Fan Replacement: étape 2, image 1 de 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Fan Replacement: étape 3, image 1 de 2 HP 15-ac121dx Fan Replacement: étape 3, image 2 de 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Fan Replacement: étape 4, image 1 de 2 HP 15-ac121dx Fan Replacement: étape 4, image 2 de 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Fan Replacement, Back Panel: étape 5, image 1 de 3 HP 15-ac121dx Fan Replacement, Back Panel: étape 5, image 2 de 3 HP 15-ac121dx Fan Replacement, Back Panel: étape 5, image 3 de 3
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac121dx Fan Replacement: étape 6, image 1 de 1
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac121dx Fan Replacement: étape 7, image 1 de 3 HP 15-ac121dx Fan Replacement: étape 7, image 2 de 3 HP 15-ac121dx Fan Replacement: étape 7, image 3 de 3
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac121dx Fan Replacement, Fan: étape 8, image 1 de 3 HP 15-ac121dx Fan Replacement, Fan: étape 8, image 2 de 3 HP 15-ac121dx Fan Replacement, Fan: étape 8, image 3 de 3
    • Locate the Fan as shown.
    • Pull out the black cable, with four wires attached from its port.
  9. HP 15-ac121dx Fan Replacement: étape 9, image 1 de 2 HP 15-ac121dx Fan Replacement: étape 9, image 2 de 2
    • Pull out the white cable wire from its port.
    • Unscrew the two black Phillips screws holding in the fan.
  10. HP 15-ac121dx Fan Replacement: étape 10, image 1 de 2 HP 15-ac121dx Fan Replacement: étape 10, image 2 de 2
    • Remove fan.
    • Unscrew the two screws holding in the fan.
Replace fan. To reassemble your device, follow these instructions in reverse order.
Onose Aigbe
Membre depuis le 01/30/18
390 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team S1-G2, Johnson Spring 2018 Membre de l'équipe Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 6
Total : 1,408
