Pièces
Aucune pièce nécessaire.
With the computer off, turn it over onto a flat surface. Remove the battery by sliding the battery lock. Remove the 10 screws.
  • With the computer off, turn it over onto a flat surface.
  • Remove the battery by sliding the battery lock.
  • Remove the 10 screws.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Flip the computer back over and use the iFixit tool in order to pry the keyboard from the bottom of the computer. Once off you will be able to see the fan.
  • Flip the computer back over and use the iFixit tool in order to pry the keyboard from the bottom of the computer.
  • Once off you will be able to see the fan.
Remove the two screws on either side of the fan. Unplug the wire that is connected to the fan.
  • Remove the two screws on either side of the fan.
  • Unplug the wire that is connected to the fan.
  • Remove the fan
Nicole Mathieu
Membre depuis le 19/03/2018
557 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G4, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G4, Bernier Spring 2018
UMASSD-BERNIER-S18S2G4
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 16
Total : 29
