Aller au contenu principal
HP 15-ay014dx RAM Replacement
Ce dont vous avez besoin
  1. HP 15-ay014dx RAM Replacement, Battery: étape 1, image 1 de 1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx RAM Replacement: étape 2, image 1 de 1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx RAM Replacement: étape 3, image 1 de 1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx RAM Replacement, Optical Drive: étape 4, image 1 de 1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx RAM Replacement: étape 5, image 1 de 1
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx RAM Replacement, RAM: étape 6, image 1 de 1
    • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx RAM Replacement: étape 7, image 1 de 2 HP 15-ay014dx RAM Replacement: étape 7, image 2 de 2
    • Use the spudger to press the tabs in the back of the computer. Carefully remove the back of the laptop by prying around the sides using the plastic opening tool.
  8. HP 15-ay014dx RAM Replacement: étape 8, image 1 de 2 HP 15-ay014dx RAM Replacement: étape 8, image 2 de 2
    • Undo the clips holding the RAM in place using the plastic opening tool.
  9. HP 15-ay014dx RAM Replacement: étape 9, image 1 de 1
    • Carefully pull out the RAM from the motherboard.
7 autres ont terminé cette réparation.
Drake Scoville
Membre depuis le 09/21/17
533 Réputation
4 tutoriels rédigés
Équipe
Washington State, Team S1-G4, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S1-G4, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S1G4
6 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 2
Total : 712
