Introduction
This guide will show you how to take the wireless card out of your HP 15-ay014dx laptop.
Pièces
Aucune pièce nécessaire.
Disconnect device from power source and power down.
  • Disconnect device from power source and power down.
Ajouter un commentaire
With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
The latch on your left will stay at the inward position, while the latch on the right will slide back out.
  • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
  • Gently grasp the battery and pull it back away from the device and yourself.
Close the laptop and lay it down with the bottom facing up.
  • Close the laptop and lay it down with the bottom facing up.
  • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Grip the optical drive and gently pull it out.
  • Grip the optical drive and gently pull it out.
Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body. Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
  • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it. Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it.
  • Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it.
Using the size #00 Phillips screwdriver remove the single screw holding it in place.
  • Using the size #00 Phillips screwdriver remove the single screw holding it in place.
carefully pull the card of its slot.
  • carefully pull the card of its slot.
Drake Scoville
Membre depuis le 21/09/2017
419 Réputation
4 tutoriels rédigés
Équipe
Washington State, Team S1-G4, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S1-G4, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S1G4
6 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 69
