Aller au contenu principal
HP 15-f009wm Hard Drive Replacement
Ce dont vous avez besoin
  1. HP 15-f009wm Hard Drive Replacement, Battery: étape 1, image 1 de 2 HP 15-f009wm Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Turn laptop upside down.
    • Flip the lock switch to the unlocked setting.
  2. HP 15-f009wm Hard Drive Replacement: étape 2, image 1 de 3 HP 15-f009wm Hard Drive Replacement: étape 2, image 2 de 3 HP 15-f009wm Hard Drive Replacement: étape 2, image 3 de 3
    • Flip the release switch.
    • Once the flip is switched, the battery should pop out.
  3. HP 15-f009wm Hard Drive Replacement: étape 3, image 1 de 2 HP 15-f009wm Hard Drive Replacement: étape 3, image 2 de 2
    • Slide the battery out.
  4. HP 15-f009wm Hard Drive Replacement, RAM: étape 4, image 1 de 3 HP 15-f009wm Hard Drive Replacement, RAM: étape 4, image 2 de 3 HP 15-f009wm Hard Drive Replacement, RAM: étape 4, image 3 de 3
    • Remove the two Phillips #1 screws from the RAM panel.
  5. HP 15-f009wm Hard Drive Replacement: étape 5, image 1 de 3 HP 15-f009wm Hard Drive Replacement: étape 5, image 2 de 3 HP 15-f009wm Hard Drive Replacement: étape 5, image 3 de 3
    • Use the plastic opening tool to pop the panel off.
  6. HP 15-f009wm Hard Drive Replacement: étape 6, image 1 de 3 HP 15-f009wm Hard Drive Replacement: étape 6, image 2 de 3 HP 15-f009wm Hard Drive Replacement: étape 6, image 3 de 3
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  7. HP 15-f009wm Hard Drive Replacement: étape 7, image 1 de 1
    • Remove the RAM chip from the laptop.
  8. HP 15-f009wm Hard Drive Replacement, Hard Drive: étape 8, image 1 de 1
    • Remove the sixteen 7mm Phillips #1 screws from the bottom panel.
  9. HP 15-f009wm Hard Drive Replacement: étape 9, image 1 de 3 HP 15-f009wm Hard Drive Replacement: étape 9, image 2 de 3 HP 15-f009wm Hard Drive Replacement: étape 9, image 3 de 3
    • Pull the disk drive out of the laptop.
  10. HP 15-f009wm Hard Drive Replacement: étape 10, image 1 de 1
    • Remove the three 2mm Phillips #00 screws found underneath the disk drive.
  11. HP 15-f009wm Hard Drive Replacement: étape 11, image 1 de 3 HP 15-f009wm Hard Drive Replacement: étape 11, image 2 de 3 HP 15-f009wm Hard Drive Replacement: étape 11, image 3 de 3
    • Remove the single 4mm Phillips #1 screw from the Wi-Fi card.
    • Pull the Wi-Fi card out of the motherboard.
  12. HP 15-f009wm Hard Drive Replacement: étape 12, image 1 de 3 HP 15-f009wm Hard Drive Replacement: étape 12, image 2 de 3 HP 15-f009wm Hard Drive Replacement: étape 12, image 3 de 3
    • Open the laptop.
    • Use a plastic opening tool to pop out the keyboard by starting at the top and working your way around the perimeter.
  13. HP 15-f009wm Hard Drive Replacement: étape 13, image 1 de 2 HP 15-f009wm Hard Drive Replacement: étape 13, image 2 de 2
    • Open the screen up until it lays flat and rotate the laptop until the screen is closest to you.
    • Lift the keyboard from the laptop.
    • Use a spudger to lift up the black latch on the ZIF connector and remove the ribbon cable.
  14. HP 15-f009wm Hard Drive Replacement: étape 14, image 1 de 1
    • Remove the five 7mm Phillips #1 screws found underneath the keyboard.
  15. HP 15-f009wm Hard Drive Replacement: étape 15, image 1 de 3 HP 15-f009wm Hard Drive Replacement: étape 15, image 2 de 3 HP 15-f009wm Hard Drive Replacement: étape 15, image 3 de 3
    • Use a spudger to lift the black tabs on the ZIF connectors.
    • Remove the ribbon cables from the ZIF connectors.
  16. HP 15-f009wm Hard Drive Replacement: étape 16, image 1 de 3 HP 15-f009wm Hard Drive Replacement: étape 16, image 2 de 3 HP 15-f009wm Hard Drive Replacement: étape 16, image 3 de 3
    • Use a plastic opening tool to pop the palm rest off of the laptop.
    • Lift and remove the palm rest.
  17. HP 15-f009wm Hard Drive Replacement: étape 17, image 1 de 3 HP 15-f009wm Hard Drive Replacement: étape 17, image 2 de 3 HP 15-f009wm Hard Drive Replacement: étape 17, image 3 de 3
    • Use a spudger to lift up the black latch on the ZIF connector.
    • Remove the USB/AUX port ribbon cable from the ZIF connector on the motherboard.
  18. HP 15-f009wm Hard Drive Replacement: étape 18, image 1 de 2 HP 15-f009wm Hard Drive Replacement: étape 18, image 2 de 2
    • Remove the single 7mm Phillips #1 screw from the USB/AUX board.
    • Remove the USB/AUX board from the laptop.
  19. HP 15-f009wm Hard Drive Replacement: étape 19, image 1 de 3 HP 15-f009wm Hard Drive Replacement: étape 19, image 2 de 3 HP 15-f009wm Hard Drive Replacement: étape 19, image 3 de 3
    • Lift the Hard Drive from the laptop.
    • Disconnect the hard drive from the motherboard.
9 autres ont terminé cette réparation.
Alex Birchler
Membre depuis le 02/14/18
1 008 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S2-G2, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S2-G2, Nance Spring 2018
USFT-NANCE-S18S2G2
4 membres
5 tutoriels rédigés
3 commentaires
This guide helped me so much with my laptop, thanks m8
Connor Cornelison - Réponse
Thank you for this excellent write-up!
Dan Snow - Réponse
Hello, i have a question. How much of capacity and technology i could use to upgrade my hard drive?
Samuel Arreaza - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 18
Total : 3,845
