Introduction
This guide will illustrate how to correctly remove and replace the optical drive of the HP 2000 - 2D22DX laptop. Partial disassembly of the laptop is required to access the drive.
Pièces
Aucune pièce nécessaire.
Flip the device over and locate the battery compartment. Slide the battery release latch, which you can see in the picture, to the left until the battery is detached from its slot.
  • Flip the device over and locate the battery compartment.
  • Slide the battery release latch, which you can see in the picture, to the left until the battery is detached from its slot.
  • A distinguishable pop will be heard when the battery is fully released.
Ajouter un commentaire
Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process. Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
  • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
Locate the Phillips head screw securing RAM compartment cover. Loosen the screw that is securing the RAM compartment with a Phillips #00 screwdriver.
  • Locate the Phillips head screw securing RAM compartment cover.
  • Loosen the screw that is securing the RAM compartment with a Phillips #00 screwdriver.
  • Screw is permanently attached to the RAM compartment cover. Do not try to remove completely.
Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis. When unclipped completely, pull the compartment door out and away from the chassis.
  • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
  • When unclipped completely, pull the compartment door out and away from the chassis.
Locate the two Phillips head screws that are securing the hard drive compartment. Using a Phillips #00 screwdriver, loosen both screws. Screws are permanently attached to the hard drive compartment cover. Do not try to remove completely.
  • Locate the two Phillips head screws that are securing the hard drive compartment.
  • Using a Phillips #00 screwdriver, loosen both screws.
  • Screws are permanently attached to the hard drive compartment cover. Do not try to remove completely.
  • Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
Locate the hard drive connecting cable to the right of hard drive. Using a spudger, disconnect the hard drive connecting cable. Use a slow, prying motion as if pulling a nail out of wood. Be very gentle with the connecting cable and its respective port on the logic board. Both are very fragile and can be easily damaged.
  • Locate the hard drive connecting cable to the right of hard drive.
  • Using a spudger, disconnect the hard drive connecting cable. Use a slow, prying motion as if pulling a nail out of wood.
  • Be very gentle with the connecting cable and its respective port on the logic board. Both are very fragile and can be easily damaged.
Using your fingers, grab the blue tab on the right side of the hard drive and slowly pull upwards. LIft the hard drive out and away from its socket in the plastic chassis. LIft the hard drive out and away from its socket in the plastic chassis.
  • Using your fingers, grab the blue tab on the right side of the hard drive and slowly pull upwards.
  • LIft the hard drive out and away from its socket in the plastic chassis.
Locate the Phillips-head screw on the left side of the hard drive recess, indicated by a red circle. Use a #00 Phillips head screwdriver to remove the small screw.  Consider using a magnetized screwdriver.
  • Locate the Phillips-head screw on the left side of the hard drive recess, indicated by a red circle.
  • Use a #00 Phillips head screwdriver to remove the small screw. Consider using a magnetized screwdriver.
Once the securing screw is removed, the optical drive can be pulled from its slot easily. Use your fingers to pull the optical drive away slowly from its position in the plastic chassis. The optical drive should slide out very easily. If you fell resistance, do not pull too hard.  Something may be caught, and you might damage the optical drive's connections.
  • Once the securing screw is removed, the optical drive can be pulled from its slot easily.
  • Use your fingers to pull the optical drive away slowly from its position in the plastic chassis.
  • The optical drive should slide out very easily. If you fell resistance, do not pull too hard. Something may be caught, and you might damage the optical drive's connections.
Conor Most
Membre depuis le 14/04/2014
2 220 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 3-40, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 3-40, Maness Spring 2014
CPSU-MANESS-S14S3G40
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 865
