Aller au contenu principal
HP Chromebook 11 G3 Battery Replacement
Ce dont vous avez besoin
  1. HP Chromebook 11 G3 Battery Replacement, Keyboard Mount: étape 1, image 1 de 2 HP Chromebook 11 G3 Battery Replacement, Keyboard Mount: étape 1, image 2 de 2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Battery Replacement: étape 2, image 1 de 2 HP Chromebook 11 G3 Battery Replacement: étape 2, image 2 de 2
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Battery Replacement: étape 3, image 1 de 1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Battery Replacement: étape 4, image 1 de 3 HP Chromebook 11 G3 Battery Replacement: étape 4, image 2 de 3 HP Chromebook 11 G3 Battery Replacement: étape 4, image 3 de 3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Battery Replacement: étape 5, image 1 de 1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Battery Replacement, Battery: étape 6, image 1 de 1
    • Gently remove the battery’s rainbow-colored bundled cable from the motherboard.
  7. HP Chromebook 11 G3 Battery Replacement: étape 7, image 1 de 2 HP Chromebook 11 G3 Battery Replacement: étape 7, image 2 de 2
    • Remove the six 4 mm Phillips #00 screws located along the perimeter of the battery.
  8. HP Chromebook 11 G3 Battery Replacement: étape 8, image 1 de 1
    • Lift out the battery.
    • The laptop may tip backwards onto its lid due to uneven weight distribution.
5 autres ont terminé cette réparation.
Rahul Goyal
Membre depuis le 04/26/17
1 369 Réputation
10 tutoriels rédigés
Équipe
Cal Poly, Team S23-G3, Livingston Spring 2017 Membre de l'équipe Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
4 membres
12 tutoriels rédigés
Un commentaire
Can the HP Chromebook 11 G3 be operated from the power adapter after the battery has been removed?
Andrew Logan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 34
Total : 3,715
