Aller au contenu principal
HP Chromebook 11 G4 LCD Replacement
Ce dont vous avez besoin
  1. HP Chromebook 11 G4 LCD Replacement, LCD: étape 1, image 1 de 3 HP Chromebook 11 G4 LCD Replacement, LCD: étape 1, image 2 de 3 HP Chromebook 11 G4 LCD Replacement, LCD: étape 1, image 3 de 3
    • Open the laptop.
    • With the plastic spudger or your fingers, gently peel off the two thin adhesive layers at the left and right bottom edges of the screen.
    • Do not pry up the plastic bezel (monitor frame), just the adhesive layer.
    • If the adhesive layer isn't coming off, use a metal spudger.
  2. HP Chromebook 11 G4 LCD Replacement: étape 2, image 1 de 2 HP Chromebook 11 G4 LCD Replacement: étape 2, image 2 de 2
    • Remove the two 3 mm Phillips #00 screws located underneath the adhesive layers that were removed in the previous step
  3. HP Chromebook 11 G4 LCD Replacement: étape 3, image 1 de 3 HP Chromebook 11 G4 LCD Replacement: étape 3, image 2 de 3 HP Chromebook 11 G4 LCD Replacement: étape 3, image 3 de 3
    • Gently pry up the plastic bezel with the small, narrow end of the metal spudger.
    • Insert the long, flat end of the metal spudger into the gap.
    • Slide the metal spudger along the edge to disconnect the bezel from the laptop
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, it's okay to use more force.
  4. HP Chromebook 11 G4 LCD Replacement: étape 4, image 1 de 2 HP Chromebook 11 G4 LCD Replacement: étape 4, image 2 de 2
    • Tilt the laptop screen as far back as possible
    • Hold the bezel with both hands, then pull the bezel towards you to disconnect the bottom edge of the bezel from the laptop.
    • You may have to use extra force for this step
  5. HP Chromebook 11 G4 LCD Replacement: étape 5, image 1 de 3 HP Chromebook 11 G4 LCD Replacement: étape 5, image 2 de 3 HP Chromebook 11 G4 LCD Replacement: étape 5, image 3 de 3
    • Remove the four silver 4 mm Phillips #0 screws at the bottom of the LCD.
    • Remove the four black 3 mm Phillips #00 screws along the perimeter of the LCD.
  6. HP Chromebook 11 G4 LCD Replacement: étape 6, image 1 de 2 HP Chromebook 11 G4 LCD Replacement: étape 6, image 2 de 2
    • Lift the LCD off its mount and gently lay it facedown on the keyboard.
  7. HP Chromebook 11 G4 LCD Replacement: étape 7, image 1 de 3 HP Chromebook 11 G4 LCD Replacement: étape 7, image 2 de 3 HP Chromebook 11 G4 LCD Replacement: étape 7, image 3 de 3
    • Peel off the clear sticker covering the display cable at the base of the LCD.
    • Gently pull the display cable from the connector.
13 autres ont terminé cette réparation.
Jonah Silva
Membre depuis le 04/26/17
785 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S23-G5, Livingston Spring 2017 Membre de l'équipe Cal Poly, Team S23-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G5
3 membres
6 tutoriels rédigés
3 commentaires
Thanks for the great guidance. Easy as pie!
lcowsert - Réponse
i need to replace the top cover of this Laptop HP Chromebook 11-2201NA Can you help
grahamcoles - Réponse
I did it! Thank you for terrific instructions.
Krenee - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 39
Total : 7,605
