Aller au contenu principal
HP Chromebook 11 G4 Motherboard Replacement
Ce dont vous avez besoin
  1. HP Chromebook 11 G4 Motherboard Replacement, Keyboard: étape 1, image 1 de 1
    • Position the closed Chromebook with the rubber pads are facing up.
  2. HP Chromebook 11 G4 Motherboard Replacement: étape 2, image 1 de 2 HP Chromebook 11 G4 Motherboard Replacement: étape 2, image 2 de 2
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. HP Chromebook 11 G4 Motherboard Replacement: étape 3, image 1 de 2 HP Chromebook 11 G4 Motherboard Replacement: étape 3, image 2 de 2
    • Remove the eleven 6mm Phillips #1 screws.
  4. HP Chromebook 11 G4 Motherboard Replacement: étape 4, image 1 de 1
    • Flip over the Chromebook and open it.
  5. HP Chromebook 11 G4 Motherboard Replacement: étape 5, image 1 de 2 HP Chromebook 11 G4 Motherboard Replacement: étape 5, image 2 de 2
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. HP Chromebook 11 G4 Motherboard Replacement: étape 6, image 1 de 1
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
  7. HP Chromebook 11 G4 Motherboard Replacement: étape 7, image 1 de 3 HP Chromebook 11 G4 Motherboard Replacement: étape 7, image 2 de 3 HP Chromebook 11 G4 Motherboard Replacement: étape 7, image 3 de 3
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. HP Chromebook 11 G4 Motherboard Replacement: étape 8, image 1 de 1
    • Remove the keyboard assembly by lifting it off the laptop base.
  9. HP Chromebook 11 G4 Motherboard Replacement, Motherboard: étape 9, image 1 de 2 HP Chromebook 11 G4 Motherboard Replacement, Motherboard: étape 9, image 2 de 2
    • Remove the cable at the top left of the motherboard by grabbing the male connector and applying force in the direction of the wires away from the motherboard.
    • Do not pull on the wires to apply more force. Instead, gently wiggle the connector until it slides out.
  10. HP Chromebook 11 G4 Motherboard Replacement: étape 10, image 1 de 2 HP Chromebook 11 G4 Motherboard Replacement: étape 10, image 2 de 2
    • Disconnect the battery wires from the motherboard by applying pressure on the male connector away from the motherboard.
  11. HP Chromebook 11 G4 Motherboard Replacement: étape 11, image 1 de 2 HP Chromebook 11 G4 Motherboard Replacement: étape 11, image 2 de 2
    • Disconnect the wire bundle on the bottom right of the motherboard by pulling the black male connector away from its socket on the motherboard.
  12. HP Chromebook 11 G4 Motherboard Replacement: étape 12, image 1 de 2 HP Chromebook 11 G4 Motherboard Replacement: étape 12, image 2 de 2
    • Use a fingernail or a spudger to flip up the black tab on the zero insertion force connector located at the top of the motherboard.
    • Remove the cable by pulling away from the motherboard.
  13. HP Chromebook 11 G4 Motherboard Replacement: étape 13, image 1 de 2 HP Chromebook 11 G4 Motherboard Replacement: étape 13, image 2 de 2
    • Use a fingernail or a spudger to flip up the white tab on the zero insertion force connector on the bottom left of the motherboard.
  14. HP Chromebook 11 G4 Motherboard Replacement: étape 14, image 1 de 1
    • Remove the 4 mm Phillips #1 screw on the Wi-Fi card.
  15. HP Chromebook 11 G4 Motherboard Replacement: étape 15, image 1 de 2 HP Chromebook 11 G4 Motherboard Replacement: étape 15, image 2 de 2
    • Slide the Wi-Fi card away from the motherboard.
  16. HP Chromebook 11 G4 Motherboard Replacement: étape 16, image 1 de 2 HP Chromebook 11 G4 Motherboard Replacement: étape 16, image 2 de 2
    • Remove the five 4 mm Phillips #1 screws from the motherboard.
    • One of these screws is black, the rest are silver.
  17. HP Chromebook 11 G4 Motherboard Replacement: étape 17, image 1 de 3 HP Chromebook 11 G4 Motherboard Replacement: étape 17, image 2 de 3 HP Chromebook 11 G4 Motherboard Replacement: étape 17, image 3 de 3
    • Lift the left edge up and away from the base of the laptop.
    • Remove the motherboard.
Jair Herrera
Membre depuis le 04/26/17
694 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S16-G5, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 33
Total : 3,767
