Aller au contenu principal
HP Chromebook 14-ak013dx Motherboard Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-ak013dx Motherboard Replacement, Battery: étape 1, image 1 de 3 HP Chromebook 14-ak013dx Motherboard Replacement, Battery: étape 1, image 2 de 3 HP Chromebook 14-ak013dx Motherboard Replacement, Battery: étape 1, image 3 de 3
    • Turn the Chromebook upside down, as shown in the first image.
    • Remove the five rubber feet pieces as shown using a metal spudger.
  2. HP Chromebook 14-ak013dx Motherboard Replacement: étape 2, image 1 de 3 HP Chromebook 14-ak013dx Motherboard Replacement: étape 2, image 2 de 3 HP Chromebook 14-ak013dx Motherboard Replacement: étape 2, image 3 de 3
    • Begin removal of the back panel by unscrewing all exposed screws using a small Phillips screwdriver.
    • Use a plastic prying tool to split the back panel from the keyboard.
    • Move the prying tool around the sides of the back panel to detach it. Do not fully remove the panel, taking note of the two ribbon cables.
  3. HP Chromebook 14-ak013dx Motherboard Replacement: étape 3, image 1 de 3 HP Chromebook 14-ak013dx Motherboard Replacement: étape 3, image 2 de 3 HP Chromebook 14-ak013dx Motherboard Replacement: étape 3, image 3 de 3
    • Remove both ribbon cables attaching the separated keyboard to the motherboard.
    • The large black ribbon cable was a tab that should be pried open to loosen the ribbon from its hub. Use the plastic opening tool as shown.
    • Gently pull out the short white ribbon cable out of its hub.
  4. HP Chromebook 14-ak013dx Motherboard Replacement: étape 4, image 1 de 2 HP Chromebook 14-ak013dx Motherboard Replacement: étape 4, image 2 de 2
    • Peel up the adhered ribbon cable. This cable does not need to be detached from the motherboard.
    • Use a plastic opening tool to disconnect the battery before going any further by inserting the tool between the plug and the hub where the recesses are on either side of the plug.
  5. HP Chromebook 14-ak013dx Motherboard Replacement: étape 5, image 1 de 2 HP Chromebook 14-ak013dx Motherboard Replacement: étape 5, image 2 de 2
    • Unscrew the four M2xL3 screws , shown in the picture, using a Phillips screwdriver.
    • Carefully lift the battery out of its place, avoiding the previously adhered silver ribbon cable in the process.
  6. HP Chromebook 14-ak013dx Motherboard Replacement, Motherboard: étape 6, image 1 de 3 HP Chromebook 14-ak013dx Motherboard Replacement, Motherboard: étape 6, image 2 de 3 HP Chromebook 14-ak013dx Motherboard Replacement, Motherboard: étape 6, image 3 de 3
    • Lift the two retaining bars above the battery with an opening tool.
  7. HP Chromebook 14-ak013dx Motherboard Replacement: étape 7, image 1 de 2 HP Chromebook 14-ak013dx Motherboard Replacement: étape 7, image 2 de 2
    • Carefully remove the ribbon cable connecting the USB ports to the motherboard.
  8. HP Chromebook 14-ak013dx Motherboard Replacement: étape 8, image 1 de 2 HP Chromebook 14-ak013dx Motherboard Replacement: étape 8, image 2 de 2
    • Unplug the red and yellow bundled wire with your hands.
  9. HP Chromebook 14-ak013dx Motherboard Replacement: étape 9, image 1 de 3 HP Chromebook 14-ak013dx Motherboard Replacement: étape 9, image 2 de 3 HP Chromebook 14-ak013dx Motherboard Replacement: étape 9, image 3 de 3
    • Remove the single 3 mm screw from the Wi-Fi card using a Phillips #0 screwdriver.
    • Remove the Wi-Fi card from the laptop.
  10. HP Chromebook 14-ak013dx Motherboard Replacement: étape 10, image 1 de 3 HP Chromebook 14-ak013dx Motherboard Replacement: étape 10, image 2 de 3 HP Chromebook 14-ak013dx Motherboard Replacement: étape 10, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the eight 1.5 mm screws from the motherboard using a Phillips #0 screwdriver.
    • Detach the black wire using tweezers.
  11. HP Chromebook 14-ak013dx Motherboard Replacement: étape 11, image 1 de 1
    • Remove the motherboard from the laptop with your hands.
This guide shows you how to replace the motherboard on a HP Chromebook 14-ak013dx.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 10
Total : 226
