Aller au contenu principal
HP Compaq 515 Keyboard Replacement
Ce dont vous avez besoin
  1. HP Compaq 515 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Turn the laptop over, the screws for the keyboard are in the middle and left of the device
  2. HP Compaq 515 Keyboard Replacement: étape 2, image 1 de 1
    • Unscrew the two 0.725 cm Screws with a PH1 screwdriver bit
    • Make sure to put the screws in a safe place so you don't lose them
  3. HP Compaq 515 Keyboard Replacement: étape 3, image 1 de 1
    • Flip the laptop over and open the screen
  4. HP Compaq 515 Keyboard Replacement: étape 4, image 1 de 2 HP Compaq 515 Keyboard Replacement: étape 4, image 2 de 2
    • Gently use a plastic spudger to remove the plastic holder at the top of the keyboard
  5. HP Compaq 515 Keyboard Replacement: étape 5, image 1 de 1
    • Gently use a plastic spudger to remove the keyboard from its holders
    • Be careful as there is a wire connecting the keyboard to the laptop
  6. HP Compaq 515 Keyboard Replacement: étape 6, image 1 de 1
    • Carefully unclip and remove the large black wire that is connecting the keyboard to the laptop
Kirsten Harnden
Membre depuis le 03/13/18
259 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G1, Covino Spring 2018 Membre de l'équipe UMass Dartmouth, Team S4-G1, Covino Spring 2018
UMASSD-COVINO-S18S4G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 347
