Introduction
The main function of this guide is to help provide a step-by-step replacement guide into replacing the battery for the HP Compaq Presario V5350NR device. Be sure that you have referenced the troubleshooting page in case that this might not be the problem that you might have.
A switch is located below the battery, take your finger and push it over to the left. The instruction to push the latch to the left is only relevant to the first image. The second image, which was included to provide a clearer image of said latch, would have the latch pushed to the right.
  • A switch is located below the battery, take your finger and push it over to the left.
  • The instruction to push the latch to the left is only relevant to the first image. The second image, which was included to provide a clearer image of said latch, would have the latch pushed to the right.
  • After this the battery should pop up and be dislodged
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the battery from its socket.
  • Remove the battery from its socket.
Ryan Dunn
Membre depuis le 18/03/2018
197 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S4-G3, Covino Spring 2018 Membre de l'équipe UMass Dartmouth, Team S4-G3, Covino Spring 2018
UMASSD-COVINO-S18S4G3
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 28
