Aller au contenu principal
HP Compaq nc6400 Keyboard Replacement
Ce dont vous avez besoin
  1. HP Compaq nc6400 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Keyboard Replacement: étape 2, image 1 de 1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Keyboard Replacement: étape 3, image 1 de 1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 Keyboard Replacement: étape 4, image 1 de 1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Keyboard Replacement, Keyboard: étape 5, image 1 de 1
    • Locate and remove the 3 screws holding the keyboard in place from underneath the laptop.
  6. HP Compaq nc6400 Keyboard Replacement: étape 6, image 1 de 3 HP Compaq nc6400 Keyboard Replacement: étape 6, image 2 de 3 HP Compaq nc6400 Keyboard Replacement: étape 6, image 3 de 3
    • Locate and remove the four retaining clips from the edge of the keyboard. To remove pry up gently on the outside edge of the plastic clip. Once the clip pops up pull it straight out.
  7. HP Compaq nc6400 Keyboard Replacement: étape 7, image 1 de 2 HP Compaq nc6400 Keyboard Replacement: étape 7, image 2 de 2
    • At this point the back of the keyboard should come up a bit. You may need to use a thin tool to pull it up, but in my case I only needed my hands. Once you have the back of the keyboard propped up as shown pull the keyboard gently towards the screen to remove. Be careful not to pull completely out because there are still connectors attached to it.
  8. HP Compaq nc6400 Keyboard Replacement: étape 8, image 1 de 2 HP Compaq nc6400 Keyboard Replacement: étape 8, image 2 de 2
    • Now with tweezers or a gentle prying apparatus gently pull the lock on the retaining clip up to release each ribbon cable. It is important to only pull up on the lock and not the entire clip.
  9. HP Compaq nc6400 Keyboard Replacement: étape 9, image 1 de 2 HP Compaq nc6400 Keyboard Replacement: étape 9, image 2 de 2
    • At this point the keyboard should be completely detached and ready to be removed. Be sure to take your time installing the ribbon cables as these can be troublesome if not installed properly
3 autres ont terminé cette réparation.
Andrew Frost
Membre depuis le 03/12/14
197 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 5-3, Cichon Spring 2014 Membre de l'équipe UMass Dartmouth, Team 5-3, Cichon Spring 2014
UMASSD-CICHON-S14S5G3
4 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 2,667
