Aller au contenu principal
HP Compaq nc6400 RAM Replacement
Ce dont vous avez besoin
  1. HP Compaq nc6400 RAM Replacement, Battery: étape 1, image 1 de 1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 RAM Replacement: étape 2, image 1 de 1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 RAM Replacement: étape 3, image 1 de 1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 RAM Replacement: étape 4, image 1 de 1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 RAM Replacement, RAM: étape 5, image 1 de 2 HP Compaq nc6400 RAM Replacement, RAM: étape 5, image 2 de 2
    • Remove the 1.2 Philips #1 screw holding down the RAM cover to the body.
  6. HP Compaq nc6400 RAM Replacement: étape 6, image 1 de 1
    • Once the screw is removed, use a spudger to pry open the case covering the RAM chip.
  7. HP Compaq nc6400 RAM Replacement: étape 7, image 1 de 2 HP Compaq nc6400 RAM Replacement: étape 7, image 2 de 2
    • Use a plastic opening tool to pull back the white clip holding the RAM chip in place.
    • Once the plastic opening tool has disengaged the clip from the RAM chip, keep the plastic opening tool locked into place.
  8. HP Compaq nc6400 RAM Replacement: étape 8, image 1 de 1
    • With a second plastic opening tool,repeat the above process
    • After both plastic opening tools have been locked in place, the RAM chip should pop out about 1/4 of a inch.
  9. HP Compaq nc6400 RAM Replacement: étape 9, image 1 de 2 HP Compaq nc6400 RAM Replacement: étape 9, image 2 de 2
    • The RAM chip is susceptible to static electricity. Before grabbing the RAM chip, make sure you have discharged the electricity from your hands by touching a metal surface other than your computer.
    • Grab the RAM chip with your thumb and index finger
    • Carefully pull the RAM chip out
5 autres ont terminé cette réparation.
Luis Vazquez
Membre depuis le 09/24/13
401 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 14-6, Forte Fall 2013 Membre de l'équipe Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 16
Total : 4,247
