Introduction
The one and only button on the HP Deskjet 1000 is the power button. If the power button is broken, you will be unable to turn the machine on. This guide will show you how to remove the button and then how to replace it.
Pièces
Aucune pièce nécessaire.
Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped). Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped). Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
Ajouter un commentaire
In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer. In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer. In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
Kits de RAM Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits de RAM Mac
Obtenez plus de mémoire sur votre Mac.
With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
  • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
Carefully hold the small clip back to release the button arm. Once the arm is unclipped, gently lift and pull the button until it disconnects at the hinge slot. Replace the old power button with a new one.
  • Carefully hold the small clip back to release the button arm.
  • Once the arm is unclipped, gently lift and pull the button until it disconnects at the hinge slot.
  • Replace the old power button with a new one.
Colin Tourjee
Membre depuis le 29/01/2018
449 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S5-G3, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S5-G3, Passmore Spring 2018
USFT-PASSMORE-S18S5G3
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 46
