Introduction
This guide will replace the gear guard, which will be hidden under the metal frame. It protects the gear from dirt and dust accumulation that would affect the printer's performance.
Pièces
Aucune pièce nécessaire.
Remove the back two 14.0 mm Torx #10 screws.
  • Remove the back two 14.0 mm Torx #10 screws.
Ajouter un commentaire
Lay the printer on its back.
  • Lay the printer on its back.
  • Grab the paper tray by its right side and pull it to the left and up.
Open the frontal access panel by lifting it from the top.
  • Open the frontal access panel by lifting it from the top.
  • Similar to the paper tray, grab it from the right side and pull it to the left and up.
Take out the two frontal 14.0 mm Torx #10 screws. Carefully lift the frontal cover. Don't lift it up aggressively. A strip will be attached to it.
  • Take out the two frontal 14.0 mm Torx #10 screws.
  • Carefully lift the frontal cover.
  • Don't lift it up aggressively. A strip will be attached to it.
Remove the five 13.0 mm Torx #10 screws found on top of the frame. Remove the four 9.0 mm Torx #10 smaller screws.
  • Remove the five 13.0 mm Torx #10 screws found on top of the frame.
  • Remove the four 9.0 mm Torx #10 smaller screws.
Lift the rail carefully as a strip and motor will be connected to the bottom part of the printer. Now detach the white strip and wires by gently lifting them up.
  • Lift the rail carefully as a strip and motor will be connected to the bottom part of the printer.
  • Now detach the white strip and wires by gently lifting them up.
The gear guard will be located on the left side of the printer.
  • The gear guard will be located on the left side of the printer.
  • Grab the plastic guard and lift it up.
Justin Taiki Fukada
Membre depuis le 25/01/2014
798 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 1-41, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 8
Total : 711
