Aller au contenu principal
HP Elite X2 1013 G3 Battery Replacement
Ce dont vous avez besoin
  1. HP Elite X2 1013 G3 Battery Replacement, Screen: étape 1, image 1 de 1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Battery Replacement: étape 2, image 1 de 2 HP Elite X2 1013 G3 Battery Replacement: étape 2, image 2 de 2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Battery Replacement: étape 3, image 1 de 2 HP Elite X2 1013 G3 Battery Replacement: étape 3, image 2 de 2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Battery Replacement: étape 4, image 1 de 2 HP Elite X2 1013 G3 Battery Replacement: étape 4, image 2 de 2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Battery Replacement, Battery: étape 5, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Battery Replacement: étape 6, image 1 de 1
    • Lift the battery out of the housing.
Asmita Sharma
Membre depuis le 04/18/19
186 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S9-G12, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S9-G12, Maness Spring 2019
CPSU-MANESS-S19S9G12
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 64
Total : 2,477
