Introduction
The HP Elite X2 1012 G2's Wi-Fi card can become damaged or disconnected over time. This guide will walk you through how to replace the Wi-Fi card in your HP Elite X2 1012 G2.
Make sure the device is turned off before starting.
  • Make sure the device is turned off before starting.
  • Orient the device so the back is facing you, with the kickstand up.
Ajouter un commentaire
Remove the six 3mm Torx T5 screws underneath the kickstand. Remove the six 3mm Torx T5 screws underneath the kickstand. Remove the six 3mm Torx T5 screws underneath the kickstand.
  • Remove the six 3mm Torx T5 screws underneath the kickstand.
Turn the device over so the screen is facing you. Place a suction cup firmly onto a corner of the screen.
  • Turn the device over so the screen is facing you.
  • Place a suction cup firmly onto a corner of the screen.
  • Lift up gently until you see the screen separate from the casing.
  • Repeat this process for all four corners.
Lift the screen up and off of the device.
  • Lift the screen up and off of the device.
  • Pry each corner up first, otherwise you may damage or crack the screen.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently. Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently. Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
Remove the screen by gently lifting it off of the device. Remove the screen by gently lifting it off of the device.
  • Remove the screen by gently lifting it off of the device.
Orient the device so that the battery is closest to you.
  • Orient the device so that the battery is closest to you.
  • The battery is the large, black rectangle at the bottom of the device.
Detach the two wire connections on the upper right of the wi-fi card by hand. Detach the two wire connections on the upper right of the wi-fi card by hand. Detach the two wire connections on the upper right of the wi-fi card by hand.
  • Detach the two wire connections on the upper right of the wi-fi card by hand.
Use a Phillips 2mm screwdriver to remove the single M2 2.0x2.0 screw holding the wi-fi card in place. Turn the screwdriver counterclockwise to remove the screw. Use a Phillips 2mm screwdriver to remove the single M2 2.0x2.0 screw holding the wi-fi card in place. Turn the screwdriver counterclockwise to remove the screw.
  • Use a Phillips 2mm screwdriver to remove the single M2 2.0x2.0 screw holding the wi-fi card in place. Turn the screwdriver counterclockwise to remove the screw.
Slide the wi-fi card out by hand, lifting the card up and out of the device. If it doesn't come out immediately,  slowly wiggle the card side to side until it slides out of its connector.
  • Slide the wi-fi card out by hand, lifting the card up and out of the device.
  • If it doesn't come out immediately, slowly wiggle the card side to side until it slides out of its connector.
Nathan Diekema
Membre depuis le 18/04/2018
109 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S18-G5, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S18-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G5
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 29
