Aller au contenu principal
HP EliteBook 745 G4 Battery Replacement
Ce dont vous avez besoin
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 745 G4 Battery Replacement, Remove the rubber plugs: étape 2, image 1 de 1
    • Remove the 10 rubber plugs from the bottom cover.
    • Remove the SD card blank from the bottom cover.
  2. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: étape 3, image 1 de 2 HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: étape 3, image 2 de 2
    • Remove the 10 Phillips PM2.5x5.0 screws in the following order.
    • After you remove the PM2.5×5.0 screws, remove the PM2.0×7.0 screw.
  3. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover: étape 4, image 1 de 1
    • Pry up on the top (near the display hinge) of the bottom cover to disengage it from the computer. Consider using a spudger.
  4. HP EliteBook 745 G4 Battery Replacement, Remove the battery: étape 5, image 1 de 1
    • Loosen the two captive screws and remove the battery from the computer
To replace the battery & reassemble your device, follow these instructions in reverse order.
3 autres ont terminé cette réparation.
Max Kletskov
Membre depuis le 04/22/20
40 307 Réputation
16 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 277 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 38
Total : 1,175
