Aller au contenu principal
HP EliteBook 850 G5 Battery Replacement
Ce dont vous avez besoin
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 850 G5 Battery Replacement, Remove the bottom cover screws: étape 2, image 1 de 1
    • Loosen the eight captive screws that secure the bottom cover.
    • Loosen the two inset captive screws that secure the bottom cover.
  2. HP EliteBook 850 G5 Battery Replacement, Remove the bottom cover: étape 3, image 1 de 1
    • Starting under the middle of the display, pry and lift the bottom cover off the computer. Consider using a spudger.
  3. HP EliteBook 850 G5 Battery Replacement, Disconnect the battery: étape 4, image 1 de 1
    • Disconnect the battery cable from the system board.
    • Remove the four Torx T8 2.0×4.0 screws.
  4. HP EliteBook 850 G5 Battery Replacement, Remove the battery: étape 5, image 1 de 1
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
Membre depuis le 04/22/20
40 298 Réputation
16 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
17 198 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 59
30 derniers jours : 299
Total : 5,828
