Introduction
The computers hard drive is where all of its data is stored and kept when the computer is turned off. Upgrading it to a larger or faster HDD or SSD is very important in keeping your computer running properly. This simple guide shows how to easily access the HDD bay within the laptop.
Pièces
Aucune pièce nécessaire.
Place the laptop face down in front of you.
  • Place the laptop face down in front of you.
  • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the back of the case.
  • Remove the back panel.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use a Phillips #0 screwdriver to remove the two 3 mm screws from the small metal HDD bracket. Lift up on the small bracket and pull it off. Lift up on the small bracket and pull it off.
  • Use a Phillips #0 screwdriver to remove the two 3 mm screws from the small metal HDD bracket.
  • Lift up on the small bracket and pull it off.
Pull out the hard drive and the small rubber sleigh that holds it. Pull the rubber sleigh off of the hard drive. Pull the rubber sleigh off of the hard drive.
  • Pull out the hard drive and the small rubber sleigh that holds it.
  • Pull the rubber sleigh off of the hard drive.
Cameron Whittle
Membre depuis le 19/03/2018
293 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G4, Valliere Spring 2018 Membre de l'équipe UMass Dartmouth, Team S8-G4, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G4
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 26
Total : 45
