Introduction
The computers RAM, or Random Access Memory, is important in helping your computer run quickly and efficiently. Replacing damaged RAM or simply upgrading to newer/faster RAM is very beneficial to extending a computers life.
Pièces
Aucune pièce nécessaire.
Place the laptop face down in front of you.
  • Place the laptop face down in front of you.
  • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the back of the case.
  • Remove the back panel.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Press outward on the plastic clips to release the RAM. Gently pull the RAM stick out of the SODIMM slot. Gently pull the RAM stick out of the SODIMM slot.
  • Press outward on the plastic clips to release the RAM.
  • Gently pull the RAM stick out of the SODIMM slot.
Repeat step 2 for the second stick of RAM and remove it. Repeat step 2 for the second stick of RAM and remove it.
  • Repeat step 2 for the second stick of RAM and remove it.
Cameron Whittle
Membre depuis le 19/03/2018
293 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G4, Valliere Spring 2018 Membre de l'équipe UMass Dartmouth, Team S8-G4, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G4
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 21
