Aller au contenu principal
HP Elitebook 2740p Screen Replacement
Ce dont vous avez besoin
  1. HP Elitebook 2740p Screen Replacement, Battery: étape 1, image 1 de 1
    • Slide the lock tab to the right.
  2. HP Elitebook 2740p Screen Replacement: étape 2, image 1 de 1
    • Lift and remove the battery from the battery compartment.
  3. HP Elitebook 2740p Screen Replacement, Screen: étape 3, image 1 de 3 HP Elitebook 2740p Screen Replacement, Screen: étape 3, image 2 de 3 HP Elitebook 2740p Screen Replacement, Screen: étape 3, image 3 de 3
    • Locate the radio antenna on the right side of the top edge of the screen. Slide the latch to release the antenna.
    • Use a Phillips #0 screwdriver to remove the two 4 mm screws recessed in the antenna housing.
  4. HP Elitebook 2740p Screen Replacement: étape 4, image 1 de 3 HP Elitebook 2740p Screen Replacement: étape 4, image 2 de 3 HP Elitebook 2740p Screen Replacement: étape 4, image 3 de 3
    • Use a metal spudger to separate bezel from laptop body. there are tabs holding the bezel on along the entire bezel.
    • Pay special attention to the hinge cover at the bottom. It has tabs at both the top and bottom.
    • Remove the bezel from the laptop.
  5. HP Elitebook 2740p Screen Replacement: étape 5, image 1 de 3 HP Elitebook 2740p Screen Replacement: étape 5, image 2 de 3 HP Elitebook 2740p Screen Replacement: étape 5, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the eight 4 mm screws that hold the frame of the screen in place.
    • Use a Phillips #00 screwdriver to remove the single 3 mm screw at the corner of the frame.
  6. HP Elitebook 2740p Screen Replacement: étape 6, image 1 de 3 HP Elitebook 2740p Screen Replacement: étape 6, image 2 de 3 HP Elitebook 2740p Screen Replacement: étape 6, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the two 4 mm screws that hold the tilt button in place.
    • Remove the tilt button.
  7. HP Elitebook 2740p Screen Replacement: étape 7, image 1 de 3 HP Elitebook 2740p Screen Replacement: étape 7, image 2 de 3 HP Elitebook 2740p Screen Replacement: étape 7, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the three screws that secure the tablet-mode button board.
    • Disconnect the two blue ribbon cables and gently pull them free.
    • Remove the PCB board from the screen housing.
  8. HP Elitebook 2740p Screen Replacement: étape 8, image 1 de 3 HP Elitebook 2740p Screen Replacement: étape 8, image 2 de 3 HP Elitebook 2740p Screen Replacement: étape 8, image 3 de 3
    • Remove the gray rubber pad at the top of the screen next to the camera.
    • Remove the 3mm screw with a Phillips #0 screwdriver
    • Carefully tilt the screen down onto the keayboard
  9. HP Elitebook 2740p Screen Replacement: étape 9, image 1 de 2 HP Elitebook 2740p Screen Replacement: étape 9, image 2 de 2
    • Fold the protective foil back from the ribbon cables.
  10. HP Elitebook 2740p Screen Replacement: étape 10, image 1 de 3 HP Elitebook 2740p Screen Replacement: étape 10, image 2 de 3 HP Elitebook 2740p Screen Replacement: étape 10, image 3 de 3
    • Unseat display ribbon cables.
    • Ribbon cables are secured with tape. Do not force the cables out of their sockets.
    • Remove the screen.
3 autres ont terminé cette réparation.
Joseph Hazel
Membre depuis le 03/24/17
329 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G4, Valliere Spring 2018 Membre de l'équipe UMass Dartmouth, Team S8-G4, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 1,345
