Introduction
If the WI-FI on your HP Elitebook 2740p is not working properly it may be time to replace your WI-Fi card. This guide will go through the steps to replace it.
Pièces
Aucune pièce nécessaire.
Place the laptop face down in front of you. Use a Phillips #0 screwdriver to remove the three 3 mm screws from the back of the case.
  • Place the laptop face down in front of you.
  • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the back of the case.
  • Remove the back panel.
Ajouter un commentaire
Remove the two  wires that are  attached to the WiFi card.
  • Remove the two wires that are attached to the WiFi card.
Use a Phillips #0 screwdriver to remove the two 3 mm Philips head screws from the WiFi card. Remove the card. Remove the card.
  • Use a Phillips #0 screwdriver to remove the two 3 mm Philips head screws from the WiFi card.
  • Remove the card.
Andrew Furze
Membre depuis le 26/03/2018
181 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G4, Valliere Spring 2018 Membre de l'équipe UMass Dartmouth, Team S8-G4, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G4
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 23
