Introduction
There are 2 RAM slots in the 6930p Laptop. One is the expansion slot and accessible from the underside of the device, the other is the default location for factory installed RAM and is located under the keyboard. This guide focuses on the expansion slot
Pièces
Aucune pièce nécessaire.
Flip laptop over and locate the battery release button Push release button to the left to release battery and gently pull battery from the laptop Push release button to the left to release battery and gently pull battery from the laptop
  • Flip laptop over and locate the battery release button
  • Push release button to the left to release battery and gently pull battery from the laptop
Ajouter un commentaire
Locate the RAM expansion slot cover on the bottom of the laptop Loosen the PM2.0×5.0 captive screw and remove the cover.
  • Locate the RAM expansion slot cover on the bottom of the laptop
  • Loosen the PM2.0×5.0 captive screw and remove the cover.
Install RAM module into the RAM slot on an angle of around 30 degrees Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
  • Install RAM module into the RAM slot on an angle of around 30 degrees
  • Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
  • Check to ensure the metal tabs are holding the RAM module down on both sides
  • Reinstall the RAM cover
6 autre(s) ont terminé cette réparation.
Richdave
Membre depuis le 09/04/2010
27 525 Réputation
37 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
274 membres
713 tutoriels rédigés
What kind of RAM do you place in this slot?
I want to upgrade my notebook, maybe with some RAM from ebay, so, What should I buy?
Jan Cerenohorsky - Réponse
Also, is there already any RAM by default? What is the maximum capacity you can upgrade to?
Jan Cerenohorsky -
Yes under the Keyboard and the Max is 8GB DDR2 6400
dcliddle - Réponse
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 79
Total : 11,132
