Aller au contenu principal
HP Elitebook 820 G1 RAM Replacement
Ce dont vous avez besoin
  1. HP Elitebook 820 G1 RAM Replacement, Battery: étape 1, image 1 de 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 RAM Replacement: étape 2, image 1 de 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 RAM Replacement: étape 3, image 1 de 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 RAM Replacement: étape 4, image 1 de 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 RAM Replacement, RAM: étape 5, image 1 de 1
    • Once the battery is removed from the device, slide both latches away from the RAM module with your fingers.
    • The latches are spring assisted and the RAM module will lift for removal.
2 autres ont terminé cette réparation.
Ashley Francavilla
Membre depuis le 02/14/18
103 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S5-G1, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 16
Total : 1,142
