Aller au contenu principal
HP Elitebook 8570w Optical Drive Replacement
Ce dont vous avez besoin
  1. HP Elitebook 8570w Optical Drive Replacement, Optical Drive: étape 1, image 1 de 1
    • Begin by removing the computers back covering.
    • Use the right slider to unlock the backing.
    • Slide the backing towards you while holding the slider to remove it.
  2. HP Elitebook 8570w Optical Drive Replacement: étape 2, image 1 de 1
    • Once the backing is removed, locate the panel to the left where the optical drive is stored.
    • Locate the single screw in the photo.
    • Unscrew the 0.8mm Phillips screw and place to the side.
  3. HP Elitebook 8570w Optical Drive Replacement: étape 3, image 1 de 1
    • Locate the small metal piece in the photo.
    • Using a tool, push the piece in the given direction.
  4. HP Elitebook 8570w Optical Drive Replacement: étape 4, image 1 de 2 HP Elitebook 8570w Optical Drive Replacement: étape 4, image 2 de 2
    • Once pushing the piece outwards, the optical drive will pop out of the side of the computer.
    • Grab the optical drive and carefully remove it from the back of the computer.
MJ Routh
Membre depuis le 11/06/17
465 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team S8-G5, Johnson Fall 2017 Membre de l'équipe Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 13
Total : 1,743
