Aller au contenu principal
HP Envy Sleekbook m6-k010dx LCD Replacement
Ce dont vous avez besoin
  1. HP Envy Sleekbook m6-k010dx LCD Replacement, Battery: étape 1, image 1 de 1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx LCD Replacement: étape 2, image 1 de 2 HP Envy Sleekbook m6-k010dx LCD Replacement: étape 2, image 2 de 2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx LCD Replacement: étape 3, image 1 de 1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx LCD Replacement: étape 4, image 1 de 1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx LCD Replacement: étape 5, image 1 de 2 HP Envy Sleekbook m6-k010dx LCD Replacement: étape 5, image 2 de 2
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: étape 6, image 1 de 2 HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: étape 6, image 2 de 2
    • Remove the stickers from the bottom left and right corner of the device with a plastic opening tool.
  7. HP Envy Sleekbook m6-k010dx LCD Replacement: étape 7, image 1 de 1
    • Remove the two 2.5mm Phillips #00 screws found underneath the previously removed stickers.
  8. HP Envy Sleekbook m6-k010dx LCD Replacement: étape 8, image 1 de 3 HP Envy Sleekbook m6-k010dx LCD Replacement: étape 8, image 2 de 3 HP Envy Sleekbook m6-k010dx LCD Replacement: étape 8, image 3 de 3
    • Use the plastic opening tool to pry the bezel free from the LCD housing.
  9. HP Envy Sleekbook m6-k010dx LCD Replacement: étape 9, image 1 de 2 HP Envy Sleekbook m6-k010dx LCD Replacement: étape 9, image 2 de 2
    • Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen.
  10. HP Envy Sleekbook m6-k010dx LCD Replacement: étape 10, image 1 de 2 HP Envy Sleekbook m6-k010dx LCD Replacement: étape 10, image 2 de 2
    • Use the plastic opening tool to remove the LCD screen from its housing.
    • Lay the LCD screen flat on the keyboard.
  11. HP Envy Sleekbook m6-k010dx LCD Replacement: étape 11, image 1 de 1
    • Disconnect the cable which connects the LCD to the motherboard.
    • Pul the LCD screen out.
2 autres ont terminé cette réparation.
codi whittaker
Membre depuis le 02/14/18
508 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S1-G4, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
4 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 914
