Aller au contenu principal
HP Envy dv6-7363cl Fan Replacement
Ce dont vous avez besoin
  1. HP Envy dv6-7363cl Fan Replacement, Battery: étape 1, image 1 de 1
    • Flip the device upside-down so that its bottom is facing up.
  2. HP Envy dv6-7363cl Fan Replacement: étape 2, image 1 de 1
    • Push the lever underneath the battery to the left.
  3. HP Envy dv6-7363cl Fan Replacement: étape 3, image 1 de 2 HP Envy dv6-7363cl Fan Replacement: étape 3, image 2 de 2
    • Lift the battery up out of its socket.
  4. HP Envy dv6-7363cl Fan Replacement, Fan: étape 4, image 1 de 1
    • Remove the circled screws from the back panel.
  5. HP Envy dv6-7363cl Fan Replacement: étape 5, image 1 de 1
    • Lift and remove the back panel of the device.
  6. HP Envy dv6-7363cl Fan Replacement: étape 6, image 1 de 3 HP Envy dv6-7363cl Fan Replacement: étape 6, image 2 de 3 HP Envy dv6-7363cl Fan Replacement: étape 6, image 3 de 3
    • Flip the laptop back over and carefully pry the keyboard frame out of the device.
  7. HP Envy dv6-7363cl Fan Replacement: étape 7, image 1 de 3 HP Envy dv6-7363cl Fan Replacement: étape 7, image 2 de 3 HP Envy dv6-7363cl Fan Replacement: étape 7, image 3 de 3
    • Lift the keyboard out of the device
    • Carefully remove ribbon cables.
  8. HP Envy dv6-7363cl Fan Replacement: étape 8, image 1 de 3 HP Envy dv6-7363cl Fan Replacement: étape 8, image 2 de 3 HP Envy dv6-7363cl Fan Replacement: étape 8, image 3 de 3
    • Flip device onto its back
    • Remove disk tray and circled screw.
  9. HP Envy dv6-7363cl Fan Replacement: étape 9, image 1 de 2 HP Envy dv6-7363cl Fan Replacement: étape 9, image 2 de 2
    • Flip device right-side-up and remove ribbon cables from plastic cover beneath keyboard. Remove plastic cover from device.
  10. HP Envy dv6-7363cl Fan Replacement: étape 10, image 1 de 3 HP Envy dv6-7363cl Fan Replacement: étape 10, image 2 de 3 HP Envy dv6-7363cl Fan Replacement: étape 10, image 3 de 3
    • Disconnect red cord from DVD drive and remove DVD drive.
  11. HP Envy dv6-7363cl Fan Replacement: étape 11, image 1 de 3 HP Envy dv6-7363cl Fan Replacement: étape 11, image 2 de 3 HP Envy dv6-7363cl Fan Replacement: étape 11, image 3 de 3
    • Remove circled screws.
  12. HP Envy dv6-7363cl Fan Replacement: étape 12, image 1 de 2 HP Envy dv6-7363cl Fan Replacement: étape 12, image 2 de 2
    • Disconnect red and white cords from blue circuit board.
  13. HP Envy dv6-7363cl Fan Replacement: étape 13, image 1 de 3 HP Envy dv6-7363cl Fan Replacement: étape 13, image 2 de 3 HP Envy dv6-7363cl Fan Replacement: étape 13, image 3 de 3
    • Gently pull circled pieces from their holsters.
  14. HP Envy dv6-7363cl Fan Replacement: étape 14, image 1 de 2 HP Envy dv6-7363cl Fan Replacement: étape 14, image 2 de 2
    • Turn device onto its back and remove circled screws from Wi-Fi card.
    • Flip device back over and unscrew disk reader
  15. HP Envy dv6-7363cl Fan Replacement: étape 15, image 1 de 1
    • Remove circled screws from blue circuit board and lift fan assembly out of device.
dylananthony
Membre depuis le 10/20/16
564 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G5, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G5, Bernier Spring 2018
UMASSD-BERNIER-S18S2G5
3 membres
4 tutoriels rédigés
2 commentaires
My laptop is a slightly different model and everything provided by the author is likely accurate for their model. I only mention this to caution that your repair may be slightly different depending on your specific model. Mine was different in a few areas though held mostly true with my dv6t-7000. Cheers!
zabadoo - Réponse
Salom menga shu modeldagi kompyuterni ustgi qopqogʻini topib pochta qila olasizmi iloji boʻlsa iltimos nomerim +998991768069 shu nomerga telfon qib bogʻlanishiz mumkin men bilan
Shamsullo Quzratov - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 22
Total : 4,345
