Introduction
Reader will be able to successfully replace their keyboard of the device. A basic understanding of simple tools such as a screwdriver is needed. Any form of electricity must be removed from device, including the charging cable and battery.
Pièces
Aucune pièce nécessaire.
Start by opening the laptop
  • Start by opening the laptop
Ajouter un commentaire
Pry off the keyboard retainer slowly working your way around the board to prevent damage Pry off the keyboard retainer slowly working your way around the board to prevent damage Pry off the keyboard retainer slowly working your way around the board to prevent damage
  • Pry off the keyboard retainer slowly working your way around the board to prevent damage
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Carefully pull up on the key board there will be 2 ribbon strips holding it attached to the key board Carefully pull up on the key board there will be 2 ribbon strips holding it attached to the key board
  • Carefully pull up on the key board there will be 2 ribbon strips holding it attached to the key board
Pull up on the two grey tabs that hold the ribbon cable into the connector. Then remove the keyboard. Pull up on the two grey tabs that hold the ribbon cable into the connector. Then remove the keyboard.
  • Pull up on the two grey tabs that hold the ribbon cable into the connector. Then remove the keyboard.
austin urban
Membre depuis le 19/03/2018
159 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S2-G5, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G5, Bernier Spring 2018
UMASSD-BERNIER-S18S2G5
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 14
