Aller au contenu principal
HP Envy dv6-7363cl Wi-fi Card Replacement
Ce dont vous avez besoin
  1. HP Envy dv6-7363cl Wi-fi Card Replacement, Battery: étape 1, image 1 de 1
    • Flip the device upside-down so that its bottom is facing up.
  2. HP Envy dv6-7363cl Wi-fi Card Replacement: étape 2, image 1 de 1
    • Push the lever underneath the battery to the left.
  3. HP Envy dv6-7363cl Wi-fi Card Replacement: étape 3, image 1 de 2 HP Envy dv6-7363cl Wi-fi Card Replacement: étape 3, image 2 de 2
    • Lift the battery up out of its socket.
  4. HP Envy dv6-7363cl Wi-fi Card Replacement, Wi-Fi Card: étape 4, image 1 de 1
    • After removing the battery, remove the circled screw.
  5. HP Envy dv6-7363cl Wi-fi Card Replacement: étape 5, image 1 de 1
    • Remove the back cover.
  6. HP Envy dv6-7363cl Wi-fi Card Replacement: étape 6, image 1 de 1
    • With the back cover removed, locate the Wi-Fi card which is positioned next to the Beats logo.
  7. HP Envy dv6-7363cl Wi-fi Card Replacement: étape 7, image 1 de 2 HP Envy dv6-7363cl Wi-fi Card Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Carefully remove gold-headed, black wires from Wi-Fi card with tweezers.
  8. HP Envy dv6-7363cl Wi-fi Card Replacement: étape 8, image 1 de 2 HP Envy dv6-7363cl Wi-fi Card Replacement: étape 8, image 2 de 2
    • After removing wires, remove circled screws from card.
    • Note: Laptop shown only has one screw holding in Wi-Fi card. Some models may have both.
  9. HP Envy dv6-7363cl Wi-fi Card Replacement: étape 9, image 1 de 2 HP Envy dv6-7363cl Wi-fi Card Replacement: étape 9, image 2 de 2
    • Wi-Fi card will raise out of device when screw is removed.
    • Gently pull card to the right to remove from device.
dylananthony
Membre depuis le 10/20/16
564 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G5, Bernier Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G5, Bernier Spring 2018
UMASSD-BERNIER-S18S2G5
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 10
Total : 362
