Introduction
Use this guide to replace a faulty service cover on your HP Envy dv7t-7200 if the back cover has been broken, damaged, or will not stay on any longer.
Pièces
Aucune pièce nécessaire.
Turn the power off and disconnect all cables and cords from the laptop.
  • Turn the power off and disconnect all cables and cords from the laptop.
  • Place the computer on its top on a flat surface with the hinges facing away from you.
Ajouter un commentaire
Slide the battery release latch to the left which is located on the right-hand side of the battery. Slide the battery release latch to the left which is located on the right-hand side of the battery. Slide the battery release latch to the left which is located on the right-hand side of the battery.
  • Slide the battery release latch to the left which is located on the right-hand side of the battery.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Tilt the battery away from you and lift out.
  • Tilt the battery away from you and lift out.
Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
  • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
  • This screw does not come out of the service cover completely once loosened.
Slide the service cover toward the front of the laptop. Lift the service cover to remove it from the laptop.
  • Slide the service cover toward the front of the laptop.
  • Lift the service cover to remove it from the laptop.
Krystal
Membre depuis le 16/10/2017
831 Réputation
8 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G3, Liner Fall 2017 Membre de l'équipe UW Tacoma, Team S3-G3, Liner Fall 2017
UWT-LINER-F17S3G3
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 59
