Introduction
This guide demonstrates how to properly remove the RAM of a HP Envy m6-n010dx.
Pièces
Aucune pièce nécessaire.
Find the battery removal slider. Slide it across while simultaneously popping out and removing the device's battery. Slide it across while simultaneously popping out and removing the device's battery.
  • Find the battery removal slider.
  • Slide it across while simultaneously popping out and removing the device's battery.
Ajouter un commentaire
Remove the five marked screws found under the battery using a philips head screwdriver.
  • Remove the five marked screws found under the battery using a philips head screwdriver.
Remove the small panel on the back by prying it off. This should reveal the hard drive. Remove the small panel on the back by prying it off. This should reveal the hard drive.
  • Remove the small panel on the back by prying it off. This should reveal the hard drive.
The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red. Gently pry off the cover to release the cable. Slowly lift the hard drive out and away from the device.
  • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
  • Gently pry off the cover to release the cable.
  • Slowly lift the hard drive out and away from the device.
Remove the highlighted screws Pry off the lower two grip pads You may need to use more force than feels necessary
  • Remove the highlighted screws
  • Pry off the lower two grip pads
    • You may need to use more force than feels necessary
  • Remove the two additional screws underneath the lower grip pads
  • Remove the large back panel to reveal the inner workings
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
Pull back the black rectangular cover to reveal the RAM Unclip the metal restraints on the side to pop out the RAM Repeat the previous step for the second RAM below
  • Pull back the black rectangular cover to reveal the RAM
  • Unclip the metal restraints on the side to pop out the RAM
  • Repeat the previous step for the second RAM below
Johnathan Morales
Membre depuis le 08/02/2018
354 Réputation
3 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 45
