Aller au contenu principal
HP Envy m6-n010dx Speaker Replacement
Ce dont vous avez besoin
  1. HP Envy m6-n010dx Speaker Replacement, Battery: étape 1, image 1 de 3 HP Envy m6-n010dx Speaker Replacement, Battery: étape 1, image 2 de 3 HP Envy m6-n010dx Speaker Replacement, Battery: étape 1, image 3 de 3
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx Speaker Replacement, Hard Drive: étape 2, image 1 de 1
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx Speaker Replacement: étape 3, image 1 de 2 HP Envy m6-n010dx Speaker Replacement: étape 3, image 2 de 2
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx Speaker Replacement: étape 4, image 1 de 3 HP Envy m6-n010dx Speaker Replacement: étape 4, image 2 de 3 HP Envy m6-n010dx Speaker Replacement: étape 4, image 3 de 3
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
  5. HP Envy m6-n010dx Speaker Replacement, Speaker: étape 5, image 1 de 3 HP Envy m6-n010dx Speaker Replacement, Speaker: étape 5, image 2 de 3 HP Envy m6-n010dx Speaker Replacement, Speaker: étape 5, image 3 de 3
    • Remove the marked screws.
    • Pry off the lower two grip pads.
    • You may need to use more force than feels necessary.
    • Remove the two additional screws underneath the lower grip pads.
    • Remove the large back panel to reveal the inner workings.
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  6. HP Envy m6-n010dx Speaker Replacement: étape 6, image 1 de 3 HP Envy m6-n010dx Speaker Replacement: étape 6, image 2 de 3 HP Envy m6-n010dx Speaker Replacement: étape 6, image 3 de 3
    • Locate the speaker.
    • Locate the tape on the speaker.
    • Peel back the tape, disconnecting it from the speaker.
    • When reassembling the speaker, make sure to use new electrical tape so it will stick.
  7. HP Envy m6-n010dx Speaker Replacement: étape 7, image 1 de 3 HP Envy m6-n010dx Speaker Replacement: étape 7, image 2 de 3 HP Envy m6-n010dx Speaker Replacement: étape 7, image 3 de 3
    • Locate the connecting wire attached to the speaker.
    • Disconnect the wire.
  8. HP Envy m6-n010dx Speaker Replacement: étape 8, image 1 de 2 HP Envy m6-n010dx Speaker Replacement: étape 8, image 2 de 2
    • Use a screwdriver to unscrew the three screws on the speaker.
  9. HP Envy m6-n010dx Speaker Replacement: étape 9, image 1 de 3 HP Envy m6-n010dx Speaker Replacement: étape 9, image 2 de 3 HP Envy m6-n010dx Speaker Replacement: étape 9, image 3 de 3
    • Remove the speaker.
Justin Lee
Membre depuis le 02/08/18
144 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 266
