Aller au contenu principal
HP Envy x360 m6-aq005dx Battery Replacement
Ce dont vous avez besoin
  1. HP Envy x360 m6-aq005dx Battery Replacement, Back Panel: étape 1, image 1 de 2 HP Envy x360 m6-aq005dx Battery Replacement, Back Panel: étape 1, image 2 de 2
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. HP Envy x360 m6-aq005dx Battery Replacement: étape 2, image 1 de 3 HP Envy x360 m6-aq005dx Battery Replacement: étape 2, image 2 de 3 HP Envy x360 m6-aq005dx Battery Replacement: étape 2, image 3 de 3
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. HP Envy x360 m6-aq005dx Battery Replacement: étape 3, image 1 de 1
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  4. HP Envy x360 m6-aq005dx Battery Replacement, Battery: étape 4, image 1 de 2 HP Envy x360 m6-aq005dx Battery Replacement, Battery: étape 4, image 2 de 2
    • Use a JIS #1 screwdriver to remove the six 4.7 mm screws.
  5. HP Envy x360 m6-aq005dx Battery Replacement: étape 5, image 1 de 1
    • Battery might cause a small electric shock.
    • Use tweezers to disconnect the battery from the motherboard.
7 autres ont terminé cette réparation.
Matthew Martin
Membre depuis le 10/10/17
711 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S13-G17, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S13-G17, Cagle Fall 2017
USFT-CAGLE-F17S13G17
4 membres
7 tutoriels rédigés
3 commentaires
Step 3 was the toughest!!! Case was difficult to separate.
Bo Hagen - Réponse
Thank you!!!! This made it sooooo easy to replace my battery!
Michelle Kuhlmann - Réponse
Excellent guide, many thanks for posting it.
stephenm.race - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 31
Total : 15,566
