Introduction
The fan is the main source of cooling for the laptop. It is the component that keeps your device from overheating, and can be the main source of noise from the laptop. This guide will show the proper removal of the laptop's hard drive.
Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top. Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
Ajouter un commentaire
Use a Torx T5 head to remove the six 5.1 mm screws. Use a JIS J1 to remove the two 7.2mm screws. Use a JIS J1 to remove the two 7.2mm screws.
  • Use a Torx T5 head to remove the six 5.1 mm screws.
  • Use a JIS J1 to remove the two 7.2mm screws.
Use Plastic opening tool to pry open the case. Go slowly around the edge.  You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  • Use Plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Battery may cause a small electric shock
  • Battery may cause a small electric shock
  • Use tweezers to disconnect the battery from the motherboard.
Use the Plastic opening tool to disconnect the power cable from the  fan
  • Use the Plastic opening tool to disconnect the power cable from the fan
Use your fingers to lightly pull the cable and disconnect it from the motherboard. Use your fingers to lightly pull the cable and disconnect it from the motherboard.
  • Use your fingers to lightly pull the cable and disconnect it from the motherboard.
Use a PH0 tool bit to loosen the four 6.5 mm screws. Do not fully remove the screws, just enough to be unattached from the  motherboard. Use a JIS J1 bit to remove the two 7.7 mm screws.
  • Use a PH0 tool bit to loosen the four 6.5 mm screws.
    • Do not fully remove the screws, just enough to be unattached from the motherboard.
  • Use a JIS J1 bit to remove the two 7.7 mm screws.
Matthew Martin
Membre depuis le 10/10/2017
501 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S13-G17, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S13-G17, Cagle Fall 2017
USFT-CAGLE-F17S13G17
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 38
Total : 214
