Aller au contenu principal
HP G62-223CL RAM Replacement
Ce dont vous avez besoin
  1. HP G62-223CL RAM Replacement, Battery Removal: étape 1, image 1 de 2 HP G62-223CL RAM Replacement, Battery Removal: étape 1, image 2 de 2
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL RAM Replacement: étape 2, image 1 de 1
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL RAM Replacement, RAM: étape 3, image 1 de 1
    • Locate three Phillips head retaining screws which secure RAM compartment.
    • Use a Phillips #0 screwdriver to loosen the screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL RAM Replacement: étape 4, image 1 de 2 HP G62-223CL RAM Replacement: étape 4, image 2 de 2
    • Use the tip of a screw driver to press the release clips away from the RAM module.
    • Once the second clip is released, the module will automatically pop up.
  5. HP G62-223CL RAM Replacement: étape 5, image 1 de 1
    • Carefully remove module from slot.
    • Be careful not to damage modules when removing them from their slots.
  6. HP G62-223CL RAM Replacement: étape 6, image 1 de 2 HP G62-223CL RAM Replacement: étape 6, image 2 de 2
    • Repeat steps 4 and 5 for additional RAM modules.
Garret Layton
Membre depuis le 01/13/15
669 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Sullivan Winter 2015 Membre de l'équipe USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 592
