Aller au contenu principal
HP G72 Memory Module Replacement
Ce dont vous avez besoin
  1. HP G72 Memory Module Replacement, Memory Module: étape 1, image 1 de 3 HP G72 Memory Module Replacement, Memory Module: étape 1, image 2 de 3 HP G72 Memory Module Replacement, Memory Module: étape 1, image 3 de 3
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
    • Turn the computer so that it faces upside down. Position the computer with the front toward you.
    • Slide the battery release latch to release the battery. Pivot the battery to remove it.
    • Loosen the three Phillips M2.5×6.0 captive screws that secure the memory module compartment cover.
  2. HP G72 Memory Module Replacement: étape 2, image 1 de 3 HP G72 Memory Module Replacement: étape 2, image 2 de 3 HP G72 Memory Module Replacement: étape 2, image 3 de 3
    • Use a plastic opening tool (or equivalent) to lift the back side of the cover. Small tabs hold the cover in place. Firmly pull up on the cover to release the tabs.
    • Remove the cover
    • Spread the retaining tabs on each side of the memory module slot to release the memory module. Remove the module as needed
2 autres ont terminé cette réparation.
oldturkey03
Membre depuis le 09/29/10
782 216 Réputation
119 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
33 membres
537 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 2,487
