Aller au contenu principal
HP Mini 1000 RAM Replacement
Ce dont vous avez besoin
  1. HP Mini 1000 RAM Replacement, Battery: étape 1, image 1 de 2 HP Mini 1000 RAM Replacement, Battery: étape 1, image 2 de 2
    • With the case closed, place the Mini 1000 top-side down on a flat surface.
    • Push both of the battery release latches toward each other.
  2. HP Mini 1000 RAM Replacement: étape 2, image 1 de 1
    • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
  3. HP Mini 1000 RAM Replacement, RAM: étape 3, image 1 de 2 HP Mini 1000 RAM Replacement, RAM: étape 3, image 2 de 2
    • Before proceeding, slide the right battery release latch to the unlocked position nearest the center of the computer.
    • Use the tip of a spudger to slide the RAM compartment cover release latch away from the center of the computer.
    • At this point, the edge of the RAM compartment cover nearest the battery compartment should pop up from the lower case.
  4. HP Mini 1000 RAM Replacement: étape 4, image 1 de 1
    • Remove the RAM compartment cover from the lower case.
  5. HP Mini 1000 RAM Replacement: étape 5, image 1 de 2 HP Mini 1000 RAM Replacement: étape 5, image 2 de 2
    • Use your fingers to simultaneously pull both RAM retaining arms away from the center of the RAM chip.
    • The RAM chip should pop up slightly from its socket.
    • Pull the RAM chip out of its socket and remove it from the Mini 1000.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 14
Total : 4,449
