Introduction
Installing new RAM (random access memory) on your netbook is quick and requires little disassembly.
Turn off and unplug the netbook before replacing the battery. Hold the netbook top-side down with the lid closed.
  • Turn off and unplug the netbook before replacing the battery.
  • Hold the netbook top-side down with the lid closed.
  • Slide the plastic battery release latches towards the lock symbols.
  • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
Ajouter un commentaire
Slide the battery out from the netbook.
  • Slide the battery out from the netbook.
Turn the netbook to view its edge.
  • Turn the netbook to view its edge.
  • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
Pull the back case off from the front edge.
  • Pull the back case off from the front edge.
Push out the two plastic prongs on either side of the RAM.
  • Push out the two plastic prongs on either side of the RAM.
The RAM should pop up allowing for easy removal from its compartment.
  • The RAM should pop up allowing for easy removal from its compartment.
  • Pull out the RAM.
5 autre(s) ont terminé cette réparation.
Heather Freed
Membre depuis le 06/10/2012
582 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 9-17, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 20
30 derniers jours : 86
Total : 5,588
