Aller au contenu principal
HP Mini 210 Netbook WWAN Card Replacement
Ce dont vous avez besoin
  1. HP Mini 210 Netbook WWAN Card Replacement, WWAN Card: étape 1, image 1 de 1
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. HP Mini 210 Netbook WWAN Card Replacement: étape 2, image 1 de 1
    • Slide the battery out from the netbook.
  3. HP Mini 210 Netbook WWAN Card Replacement: étape 3, image 1 de 1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. HP Mini 210 Netbook WWAN Card Replacement: étape 4, image 1 de 1
    • Use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. HP Mini 210 Netbook WWAN Card Replacement: étape 5, image 1 de 1
    • Pull the back case off from the front edge.
  6. HP Mini 210 Netbook WWAN Card Replacement: étape 6, image 1 de 2 HP Mini 210 Netbook WWAN Card Replacement: étape 6, image 2 de 2
    • Disconnect the two gold antenna cables from the WWAN card using a plastic opening tool.
  7. HP Mini 210 Netbook WWAN Card Replacement: étape 7, image 1 de 2 HP Mini 210 Netbook WWAN Card Replacement: étape 7, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the two Phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board.
  8. HP Mini 210 Netbook WWAN Card Replacement: étape 8, image 1 de 1
    • Remove the WWAN card by pulling the WWAN card out at an angle.
Install the new WWAN card and then to reassemble your device, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
Heather Freed
Membre depuis le 10/06/12
723 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 9-17, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 membres
8 tutoriels rédigés
2 commentaires
apakah benda tersebut ada dalam paket penjualan, atau dijual terpisah?
rioarayana - Réponse
I wonder sims slot on hp mini and other major brands also. Toshiba ,Acer
Deborah Kisilywicz - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 5,712
