Aller au contenu principal
HP Mini 210-2070NR RTC Battery Replacement
Ce dont vous avez besoin
  1. HP Mini 210-2070NR RTC Battery Replacement, Battery and Service Access Cover: étape 1, image 1 de 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR RTC Battery Replacement: étape 2, image 1 de 3 HP Mini 210-2070NR RTC Battery Replacement: étape 2, image 2 de 3 HP Mini 210-2070NR RTC Battery Replacement: étape 2, image 3 de 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR RTC Battery Replacement: étape 3, image 1 de 3 HP Mini 210-2070NR RTC Battery Replacement: étape 3, image 2 de 3 HP Mini 210-2070NR RTC Battery Replacement: étape 3, image 3 de 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR RTC Battery Replacement: étape 4, image 1 de 1
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR RTC Battery Replacement, RTC Battery: étape 5, image 1 de 3 HP Mini 210-2070NR RTC Battery Replacement, RTC Battery: étape 5, image 2 de 3 HP Mini 210-2070NR RTC Battery Replacement, RTC Battery: étape 5, image 3 de 3
    • The RTC battery is a thin disk near the bottom left corner.
    • The black and red cable is the RTC battery cable.
    • Pull the RTC battery cable out of its socket.
  6. HP Mini 210-2070NR RTC Battery Replacement: étape 6, image 1 de 2 HP Mini 210-2070NR RTC Battery Replacement: étape 6, image 2 de 2
    • Gently pry the RTC battery upward with the plastic opening tool.
    • Remove RTC battery.
    • The RTC battery is attached with double sided tape.
2 autres ont terminé cette réparation.
Alek Linquist
Membre depuis le 10/05/12
123 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-23, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 1,251
